Timing and idle setting question?
chanley talon
773
14
Nov 10, 2005
Spencer, Indiana
There is a little black cap that goes over the connecter in the engine bay you ground. If you loose the cap will it mess something up? How significant is the cap?
If you have not ever set your timing than you would not or your idle. Next to the battery negative side. the is a black plug with a cap on it that needs grounded in order to set base timing. I need to know if i lost that cap will it matter. Does it need to go back on? Thanks for you help maybe this will clarify it.
You can use electrical tape to cover it and tuck it away or go to a junk yard and find another cap.
it really does not do anything an i apologize LOL i didnt realyize what you were talking about right away but no its not important.. like the other guy said black tape or a junkyard... im pretty sure they are eaasy to replace or even leave... just tape it up
