DJ Robu5t
- 0
- Apr 9, 2014
Lehigh Acres,
Florida
Finally got my gsx running good, fixed all of the boost leaks and vacuum leaks, got dsm link. Tried to get a base tune (proving to be difficult as it's my first time tuning this much), running right around 14.7 at idle now, and once it boost it pegs straight to 10 and then gets richer.
On to the problem, at idle I hear a ticking/knocking type noise, we don't believe it's rod knock as it goes away with throttle and it's not nearly as loud as most rod knock you would hear, you can hear it a bit louder around 2500 when you let off, but it's gone after 2500 rpm. It's not very loud, but it's definitely noticeable, sounds more towards a tick than a knock (what I would imagine to be a hammer).
On a side note, but somewhat related, I get raw knock of around 3-5 at idle, and anywhere from 20-40 cruising, that seems odd to me, we just replaced the knock sensor as well. The weirdest thing is that I get almost no knock retard through a full pull, most I will get is 0.7 degrees knock retard. Why am I getting 30+ counts of raw knock just cruising and no knock retard.
Any help would be greatly appreciated! I'm getting my shop to do a compression test Monday, just trying to get some research done before then so I can narrow it down.
