idle surge went away.. now low idle.. IAC?
pandaswag
36
Nov 8, 2011
Naperville, Illinois
Had an idle surge for about a month.. Went away magically.. a week later. Check engine light comes on again.. and im idling at 300-500 rpm.. and if the weathers nice and im lucky itll idle around 1k normally..
I also have a horribly bad oil leak, and a belt was screaming about a month ago but it went away..
plan on taking it to the shop this next weekend and having all this bullshit diagnosed... im starting to give up on my dsm..
Car is 1995 Eclipse GS 5 speed
try adjusting your IAC, is your car the 4g63nt or 420a? im having trouble remembering which none turbos are around anymore LOL i have always went with 4g63t. Maybe your biss screw is out of wack too? Where is the oil leak coming from?
I would check your codes like the other dude said, might be tough. you got a 95 you might not have obd2 for a reader at advanced auto or if you own a reader. idk how many vacuum lines a N/T has but yes check those as well. I would be more concerned with the oil leak first tho. Your car will drive with with a wacked idle but it will only go so far with an oil leak
your best bet is to actually start with getting the code and after you get the code, do the proper testing before you go out and start buying parts and basically like the others guy said look for leaks.
also in 95 some cars have the connector of obd2 but is not compliant to the ob2 scanner cause they only made it mandatory in 96. you might have ob1 but i coud be wrong though. i believe the difference is between if its an earlier model 95 or later model.
