2G Tial wastegate fitment
You have the wastegate in the right position.
I think the problem is the manifold. What brand is it and what brand o2 housing is that?
It hard to tell what exactly what doesn't fit and a vague description :)
02 housing is pr, the wg is tial, the manifold on the other hand i have no info on and am under the impression its lower quality.
It started with alternator clearance, I fixed that with a relocation kit, now its the driver side radiator fan that won't fit.
Gotta sacrifice some things for other. If you can't get it to fit, Mount a fan on the other side of the radiator.
The 2 bolt style always seems to have clearance issuses, the newer mvs 38mm solves most of these way better for fan room.
It's just a big evo 16g. I'm running this combo because its the best parts combo I have. The obvious solution is just run a internal wastegate and a better manifold. But I hate to let a decent setup just sit around.
I had this problem and had to switch to a Turbosmart 38mm waste gate. its much more compact.
