tial wastegate and manifold
fastaseagle
64
Dec 17, 2003
london, Ohio
I have a tial wastegate and a 2g manifold with the flange.. the only problem with the setup is its off the number 4 runner insted of the number 1 will I have any performance losses or should I expect anything strange running that setup... also ther are supposed to be 2 nipples on the wastgate one on top and the other on the back side.. i only have the one on the backside do i need to run both or just one from my boost controller to the wastegate and from the boost controller to the turbo...thanks :thumb:
The runner shouldn't be problem because the manifold pressurizes the same. As for the nipples you need to get another one. The one on the top should run to your mbc while the other connects to your bov/intake line to equalize pressures. The tial site has a diagram for more info.
the runner issue should be fine, as for the wastegate, as stated above, the bottom nipple need to be tapped into any supply line BEFORE the Throttle body. The top nipple can be left off, but psi cannot be adjuststed becaust of the sping inside. They are preset at a psi you order. Say if your w/g is set with 13psi, it'll pop open at 13 no matter what. The top nipple is just there for routing it to a boost controller to add more air pressur to the spring to adjust the psi it takes to open the valve.
