Tial BOV flange leaking badly
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
I just did my first boost leak test and could only build 10psi. The main culprit is the tial bov flange. I took it off and tried using some copper spray, but it still leaks nearly as bad. I had the i.c. pipe powder-coated and the powder coater sprayed the flange. :nono: I'm thinking this is my problem. Can anyone affirm this will cause a major leak and is there any way to remove the powder coat from the flange?
your using the proper O-ring on the bov flange between flange and bov? if your using this gasket, a bit of powercoat won't effect the seal, my pipes are coated and I have no issues. Make sure the gasket is in place correctly.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
