leaking badly......!!
vicky_turbo
59
Jun 23, 2003
UAE,DUBAI, Asia
hi! i had my boost set to 15 psi,i hav all the stage 1 mods,problem is wen i set my mbc to 15 it drops to 12psi,and wen i connect it to standard only.5psi was lost,wot could be the problem comin from the root ,i havent done the leak test yet
any replies aprreciatable
This most likely your problem. Even if you don't have leaks, eliminating it will make troubleshooting much more simple. Boost leak test is crucial to turbo car and should be done regularly as new leaks can develop for many different reasons.
There are some simple tests you can do to see if others are in play if boost leak test doesn't yield any results.
1. Test run with actuator nipple open (all out boost), feather the throttle to keep boost at about 16psi. If problem solved, the mbc is the problem. If problem persists, go to 2.
2. Check for any exhaust leak before o2 housing. No leaks? go to 3.
3. Turbo would be the only thing left, check it for shaftplay and that it spins freely.
Remember, 1,2 and 3 only holds true after you're sure there are no leaks so do the boost leak test first. Good luck.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
