throttle cable (with cruise control)
spawn87
908
3
Dec 6, 2007
sacramento, California
OK so i looked at all the threads and didnt find what i was looking for.
i still have my cruise control in and i plan on keeping it in for now.
what im looking for is the part number for the output wire from the TB to the black box. any help is greatly deprecated.
cable its self is still intact but the plastic cover is half baked of. the cable is all the way look on the TB with plenty of play but once the car is hot that cable gets tight and sometimes causes my idle to b like 2k.
though i could be my IAC but that wouldn't explain why the cable tightens up on its own.
MB904111 is the part number. You probably don't need a new one (unless its a cosmetic fix) because it just needs adjusted a bit. The cable was probably adjusted when the car was cold so when things heated up they expanded and raised your idle. To adjust it properly warm the car up and adjust the throttle cable while its idling warmed up, see if you can't drop the RPM down to where it should be.
:dsm:
well ive tried it already the two bolts holding it down to the intake are all the way out for most play i can give it. and i had already loosen the black box end also but still keeps tightening. so i though i just get a new one with good cover and insulation for the heat.
thanx for getting me the part number.:thumb:
