throttle body seals?
Logue
408
6
Sep 27, 2003
Tuckerton, New Jersey
i was wondering if the throttlebody seals are same for 1g tb and 2nd gen tb. I did the seal replacement on the vfaq and i have a 1st gen throttlebody. The car on vfaq was 2nd gen. The throttlebody is returning slowly i think the seals are slowing it from returning. If they are different does anybody know what size they are??
thanks
JJ
I believe 91+ TB used the same seals. I used the them to do mine. The 89-90 TB's are reported to be different on at least one side of the shaft.
Did you fully rewind the return spring. Are you sure the seals aren't in crooked(did the shaft turn freely before you put the spring back?)
Steve
it did spring back correctly it was just a little tight, but i have driven the car around more know it just gets stuck at about 1800 rpm when you come to a stop.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
