Threw a CEL...
Batmobile
431
Feb 23, 2004
Olathe, Kansas
And they were:
P1105 Fuel Pressure Solenoid Malfunction
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
I'm in the mist of moving so I don't have my cd on the caps on where these 2 items are...so could someone help me out w/ finding these 2 problems???
dude, i have this same exact problem!
I was talking to some of the dsm techs over at a local shop and they suggested that i should buy a new gas cap. So, I went to the mitsu dealer and bought one. The cel still stayed on after resetting it. I just bought an apexi safc 2, im going to see if this helps with it. I will tell you what happens. As far as i know it, you can take you car into a shop and have them order the parts necessary and they will fix it. Im not quite sure how much it would be. Although, it doesnt seem like a major problem.
If you want to shut the CEL light off you could try pulling the 12 fuse for your radio out of the fuse box under the hood. This resets everything, even the ECU. Your car might run like crap for a couple of days but, if the light is bothering you, its worth it.
If anyone has this problem or has a solution for it....PLEASE post a result. Thanks :dsm:
I just fixed that same thing. Same as what the guy said before but it fixed mine, new gas cap. 7 bucks at shucks put it on disconnect your battery for about 10 minute then connect it and you're good to go.
lately my cel will come on at random times when i'm driving. How do u check for what the prolem is? dont u use a voltmeter and it gives u a reading? is there a tech article on this i can view?
also i've just een unplugging the negative side on the attery and reseting it and that turns off the cel for a while then it will come on again. Any suggestions?
