This turbo?
ExpresS
280
May 12, 2009
Deptford, New Jersey
Precision has quite alot of discontinued turbos. I'd like to find out more about this turbo before i start hauling ass. The pic of the compressor wheel won't upload yet. I've searched and actually found a thread similar to mine. Previous owner said it was a PTE SCM 52..e? Sound close?
Uploaded with ImageShack.us
A/R .60
Mistubishi flanged with precision stamped on the back of the turbine housing. That's all the info i can find.
The only Precision compressor wheel I know that has the machined-down hex on the front of the wheel like that is used on the 6152, so being a bolt-on turbo with a Mitsu turbine housing, yours would be considered a SCM6152E.
ALL Precision turbos have the model number engraved in the compressor outlet.
The .48 and .63 #'s you're looking at are in reference to the turbine housing and you're trying to match it up to a # you're seeing on the compressor housing. Just pull the silicone off the turbo outlet as Justin and I suggested, there should be a part # there and you'll know exactly what you have.
