This is a weird one...
ktwDSM
Jun 8, 2009
Rochester, New York
First off mods, 550cc injectors, wally 190, 14b, safc, open dump tube
Today for some reason this just started happening.. but when my cars at a stop the lights on my dash get real dim along with my headlights then when i accelerate and start to move my lights get bright again along with my headlights and my car starts to knock a little bit... any ideas on what could be going on? and along with all of this my cd player stopped working out of nowhere :hmm:
Check your altenator and battery. Those should be the first two places you check when something like that is going on. Take it to a Autozone and then can test it for you.
Yeah it sounds like a charging system issue. Check your grounds in the engine bay and get your battery/alternator checked out.
Ide check the alternator for sure, same thing happened to me except i broke down on a back road with a bunch of pissed off rednecks and mexicans staring at me from their trailers. No bueno.
definitely sounds like your alternator isnt putting out enough amperage. Get your charging system tested at a garage for $30 or advance auto parts for free. Advance has the capability of running a full system test in one shot instead of taking two different tests. and they can also give you a print out of the test to show you what the voltage and amperage is. (used to work there)
thanks for all the advice everyone, im going to go up to auto zone right now and get it checked out!
and no i don't have subs
So i went and got the altenator and battery tested, altenator tested out great!... and i have a bad battery!
Thanks to everyone that helped out! :thumb:
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
