turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Well, tonight i was going for thai food and on the way there and back i was running the wide band and hahd a fuel trim knob setup to play with the fuel curve. I was at 20psi on pump gas + meth (80% to 20% water) with an M10 nozzle. I started off in third after baselining my AFR's and dialing 6% out in the entire map via the trim knob. I was at 20psi, 16* timing and 12.2:! AFR and pulling harder than ever in third with NO KNOCK and then boom! The tranny let loose, third and fourth are gone. I still have the remaining gears, but now i need a trans and FAST!!
But the point being, i'm not knocking on 12.2:1 AFR with a meth nozzle at 80/20 and only 16* timing (timing pulled to 16 on purpose I could have ran more easily)
In a way this is good, but overall it sucks, i'm starting to extract the tune to make big power now that i'm learning i just hapen to need a transmission ...it seems like nothing is going to let me finish this tune :
<---that was the look on my face
