Tensioner arm question
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
I bought my car after someone had tampered with the tensioner arm and it didn't have any washers or anything between the bolt that holds it on and the arm itself, thus pinching the arm against the block. I put a washer in there to give it some space, but the arm still gets stuck. Does anyone know what type of washer/bolt/etc. goes there?
Thanks
Thanks
Lets start with the part numbers, according to CAPS:
MN119896 - Tensioner arm
MF241251 - bolt
MD129421 - washer
Make sure you have the correct tensioner arm. I put a light coating of assembly lube or white grease on the tensioner arm shaft and inside the tensioner. Slide the tensioner on. I also put a light coating of lube on the outside of the tensioner where the washer will make contact. With the above washer against the tensioner, torque the bolt to spec. Do not put a washer behind the tensioner. Also, don't use any old washer that seems to fit. The washer you tried may be weaker and could be bending, causing the pinching. If you still have a problem with it pinching, I would suspect you may have the wrong or damaged tensioner or you have overtightened the bolt.
Mike
You should be able to find a PDF version of the manual on the web. Just do a search on this site.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
