TDo5
Needsoles
154
Aug 9, 2007
windsor, California
I just pulled the turbo out of my 1G Eclipse and I was surprised to see that the number on the side of the housing is not TD04, but TD05H. I am wondering if these turbos came on this model of DSM or if it was swapped in at some time. The part # on the turbo is 49178-01030. Thank you for any help you can give me.
What big_d said.
The 1g manual transmission cars came equipped with a TD05H 14b turbo, which is in the same family as the 16g, 18g, etc. The automatic transmission cars came with the TD04 13g turbo. If your car is an automatic, then at some point in the past, someone replaced the turbo with a larger one.
But just to be sure, check the compressor blades of your turbo. If they're all the same height, then it's a 14b. If the fan blades alternate height, it's a 16g variant.
