Td06 Turbine In A Td05 6cm Housing?
I would say try it and find out. A used 6cm turbine housing can't cost more than $100. I had a 6cm turbine housing and manifold on my 16g and the difference in spool between that and the 7cm housing was 3200 rpm spool vs. 3500 rpm . This was with as 10* clip on a td05h exhaust wheel. But a 7cm housing is slight overkill on a small 16g. What I mean is that you could still get every last ounce out of the compressor and not be choked in the turbine housing. What kind of compressor are you running with the TD06 exhaust wheel.
