TD06 exhaust turbine outlet pipe
pat white
252
224
Jun 10, 2017
West Bay, NL, Canada
I am looking to source an outlet pipe for a TD06 exhaust housing ...it has a piston type ring seal that fits inside the housing...here is a post of a similar exhaust housing ...as you can see it is neither vband or bolt up..can't seem to find any info
I would recommend having a shop make something up or swapping to a different housing.
Might be similar to a marmon flange, just uses a retaining ring internally? Personally it sounds pretty leak-prone to me.
That does not look like a TD06 turbine inlet, or turbo really.
If the turbine outlet does indeed look like that, I'd be welding a v-band on it or something because there is no way you would figure out an easy solution that doesn't leak. But truthfully the fix would probably cost just as much as that turbo did.
