TD04H Cracked Exhaust Side
Lone
30
Feb 23, 2011
Nampa, Idaho
Recently purchased a 91 Eclipse GSX A/T with a shot TD05H the previous owner had put on it. The car came with several spare parts including the original TD04H turbo. I'd rather get it back to stock ans running right before doing anything else to it, so I am going to rebuild the TD04H first.
Any idea where I can find a replacement for the turbo exhaust side?
[/URL] Uploaded with ImageShack.us[/IMG]
That might be hard to find, most people threw away the stock auto turbos. If you can't find one, you might have your local welding shop weld it up. They should be able to use the tig with stainless rod and get it patched up to hold for a good while.
Your wanting to use the td04 13g? See I'm not the only crazy one who likes the 13g.Why not just use the slightly larger tdo5h(14b,guessing)?
There is nothing wrong with either or.I like all cup sizes to be honest;)
I have a 91 Laser RS which is my daily driver and the GSX is my son's car. I've thought about saving the TD05H for the Laser, but it has been running so well I hate to mess with it and all the work to do it. I'm trying to keep things simple for now as the GSX needs a lot of little things fixed.
I am a bit concerned about the large amount of shaft play that the TD05H had, so I'm thinking of flushing the motor and pulling the pan. Any tips for this?
As you can clearly see, it is not getting any better. I wish people would take better care of their turbos.
Pssssshhhh,Attention all passengers, were experiencing a passenger flying the plane,were all gonna die.
That was bad.Pssshhhhh attention all passengers, were experiencing some turbulance because I'm getting a B jay.
No.I don't want a large Farva,I want a Go* D**m liter of cola.Yeah, that will work just fine.
