TB Shaft seal LEAK question
The plymouthlaser.com walk through is great and you may even be able to find the correct o-ring at the local hardware store. Just remember to mark the tps and spring.
I am changing mine right now. It only takes 15 minutes to get the throttle body off the car and taken apart. It will probably take 5 minutes more to put back together due to the springs. It's not hard at all though.
The effects are:
1. Vacuum leak in off boost situations.
2. Boost leak during boost.
The seals from MachV have the metal casing. They are a complete replacement and ready to be installed right out of the package. Remember to put a dab of grease on them before install.
