TB shaft won't seal
solson1041
110
Oct 25, 2010
Indianapolis, Indiana
Hi guys, I've got a 93 tsi, and it's been giving me boost leak problems. A while ago I narrowed it to the TB shaft and have replaced the seals with the O ring method. That didn't seal it well enough, so I ordered the seals from Mach V Motorsports. They came today, I put em on the TB shaft.... and it still leaks. I didn't do anything special, a dab of dialectic grease cause that's why the Vfaq said to use on the O rings (though I don't see why dialectric is important personally).
Why is my TB still leaking. It's definitely the seal on the spring side not sealing. Is there some installation procedure I should have followed which I didn't?
Any help is appreciated, Thanks.
which seals? I used the mil.spec from STM and they have 0 leak. Dielectric grease helps seal the air. You cant use too much really. Well you can, but you would have to try to. It not like "oh oops I accidentally put too much on."
You did not install it correctly. Try reinstalling it, make sure it goes in flat.
I had it in flat. Perhaps it ended up getting shifted around as I put the spring on. I guess I'll take another go at it and hope for the best. There's really not a lot of variables here, the seals are correct and the TB itself doesn't have any gaping holes or anything, I just didn't know if I missed some part of the black magic involved in keeping a DSM running strong LOL.
Thanks for your help
