Tachometer
blueman803
216
Nov 3, 2003
chapin, South Carolina
Where does the gauge get its signal for RPMS? Does it come from the ecu or is there another source? And what is normal operating temp?
On the DOHC 4G63, both generations, the tachometer signal comes from the tachometer gate. Both the meter and the ECU use the signal. On 91-99 cars it comes from the power transistor module. On '90 cars it comes from the tachometer gate on the coil pack.
Steve
I am no longer using the stock ignitor. Does the 90's coil pack depend on the ignitor? Or is a seperate part that generates the signal? Can I just use the 90's coil pack and run the tachometer signal to the 91 tach wire?
I am using megasquirt, it has internal VB921 transistors to control the coils.
After some searching it appears I could swap out a 90 coil pack to drive the gauge? Would this work? The 90's coil pack creates the rpm signal off of the actual coil, where as the 91-94 uses the ignitor to create the signal? So I can get the noise filter and use a 90's coil to drive the gauge?
