HondaKiller
- 234
- 1
- Feb 23, 2003
Okay, so I swapped my 90 guage cluster out for a 91 and the tach doesn't work.
I know the two are not compatible straight away with the inverted tach signal. I know if you are swapping ECUs or wiring harness and stuff you need to switch pins 6 and 14 to make it work. I need to know if swapping these two wires on my 90 ECU will make my 91 tach work without messing something else up.
Or if there is a different way to make the tach work that I haven't heard of it would be appreciated.
I'm going to try swapping the tach mechanism in the clusters, maybe that will work...
