Resolved ISC solenoid pinout 90 vs 91+ question
Elpizer2
167
21
Jul 31, 2022
Miami, Florida
Ok so I'm trying to install a 90 ECU but I think my wiring harness is 91+
On internet it says this, but what pins do I need to swap in order to run a 90 ECU?
1G 4G63 ISC (Idle Speed Control) Motor wiring: (Connector B-04)​
Note: This connector is the same 6 pin connector as the Injector Resistor connector. Don't mix them up accidentally when installing your wiring harness into your vehicle.
  • Pin 1 - Blue - Goes to pin 58 at ECU
  • Pin 2 - Red
  • Pin 3 - Yellow - Goes to pin 59 at ECU
  • Pin 4 - Black - Goes to pin 68 at ECU
  • Pin 5 - Red
  • Pin 6 - White -Goes to pin 67 at ECU
Not sure I understand your question. The wiring is completely unrelated to the physical position of the ISC stepper motor.
If you’re asking which configuration you currently have, I updated the above post with the wire colors that would relate to each.
Ok but do I know the ISC position? watching at the ISC valve pins or watching on the connector unplugged?
If you're asking which pins are what numbers maybe this will help.
