T25 oil feed line
1995gsxawd
95
Aug 23, 2009
North Vernon, Indiana
Ive searched time and time again but to no prevail. I bought a SS Oil feed line from MAperformance, heres the link: Turbo Oil Line Kit / DSM stock turbo - Modern Automotive Performance When i got the kit the Banjo bolt didnt thread into my stock t-25. The banjo bolt was to big. So i emailed them trying to get a new bolt and they asked me for the size well i had no idea so i had to roughly guess and needless to say i got the wrong size. So can anyone tell me what size banjo bolt i need to hook this SS line up? the first bolt was a 12mm and it was too big and a 10mm bolt is to small so im thinking 11mm?
Almost positive it's a 12mm on a 14B...
Guess I’m not sure what a T25 has but I would assume it's the same? I'm guessing you don't have the original bolt that was on the car from the factory. If you did you could take it to a local hardware store and find out what thread it is..
Did you put in "2G" as the option when you purchased the line? If not, you probably got the 1G 14B line which would have a 12mm x 1.25 banjo fitting on it.
The T25 line is just 1/4" tube thread, like brake line. You can literally run your own line using a piece of auto parts brake line for $5.
yes i selected 2g as the option when i purchased it. I still have part of the old oil feed line its just snapped towards the end. So i bought this line thinking it would just bolt right up but that just isnt the case. ill be taking it to an auto parts store to see what size it is.
heres the factory oil feed/drain bolt info for a 2g...
-Turbo Oil Supply Line to Head-
banjo bolt + 2 16mm copper washers (shaft diameter x thread size) 10 x 1.25mm (length) 20mm (thread length) 12mm (head size) 17mm
-Turbo Oil Drain Line to Oil Pan-
(2) bolts + lock washer + 18mm washer (shaft diatmeter x thread size) 6 x 1.00mm (length) 25mm (thread length) 18mm (head size) 10mm
hopefully with that info you can find what your looking for...
:dsm:
My oil supply line isnt ran from the head its ran from the oil filter housing. I dont know if that makes a difference or not.
EDIT: I just went ahead and bought a different line kit im tired of running around all the stores in my town which dont sell what i need ha ha I just bought this oil line http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380205166876#ht_1165wt_939 Which in fact if you read the description It says a 11mm banjo bolt so hopefully i get the correct items.
