Swap issues
Wakenair11
Sep 10, 2007
Brookfield, Connecticut
Ok First of all I have searched every possible topic as well as double checked every connection... I just tried to crank over my motor after finishing a 6 bolt swap and... nothing. I tested the pump and it works fine, however it doesnt kick on at all when i turn the motor over. All of the lights kick on when the key is put it, but when u go to turn it over... nothing.
* Also v3 isnt picking up my ecu if that makes a difference? I thought the key had to be in the on position...
is the starter in and hooked up? I had a neighbor do that last year and it took him and me 2 hours to realize it. LOL
Sounds like a bad wire going to the starter. Make sure ECU harness is tight make sure all connections to the starter are tightly connected pay extra attention to the ground wire. Im sure you already checked but your battery isnt dead?
no the battery isnt dead and ill double check everything again. Why wont the eculink recognize the car tho?
