2G Suspension preference question
This is an impossible question to answer without knowing the purpose of the car. Drag car? Street car? Autocross? Road course? Multipurpose? Any compromises? Budget? Current car condition?
The point is there is no "best".
There are some general rules for improvement over stock. If you want to look cool add springs. If you want to improve handling add better struts. If you add springs you have to choose ride height and understand that doing so changes things. Geometry changes as does travel so likely spring rate changes which will affect ride quality.
I have a street car so I was just looking for improvement over stock with higher cornering ability and less understeer. Given the age of the car I chose to replace all the cars bushings to energy suspension urethane plus koni yellow struts, eibach prokit springs and rm sway bars.
More grip needs more tire. I would recommend you don't choose cheap tires. There are some good inexpensive brands that do perform well. It has been my experience you get what you pay for. Tires have been the biggest improvement for dry grip and some choices wet grip too. Almost always higher grip tires also meant higher peice and faster wear. I've had some that were bald in 9k miles. That isn't a choice everybody can live with.
Please check out this thread. It may help you plan the whole car.
My question isn't for any type of car build specifically, it's just to see what someone considers the best brand, build, etc. for their intended usage per their preference, anyone can answer with any car build in mind
The question is too vague. Best for what??
If you're asking trusted brands koni and eibach have been trusted for years. I do believe eibach caters more to the "looks" category rather than performance as I feel they're a bit soft.
What you're asking is difficult to answer without some objective comment of what you want the car to do. There is no "best"
You can go from $500 to $5000 coilovers so its not as easy as whats best as we will say the most expensive but wont be good for a normal road user as they require loads of setup and adjustment time.
No one can really answer your Q as you dont give any base to go off. People can use costly self adjusting or basics.
For basic, low cost road going then simple shock and springs are good. I used this on my old Nissan and acted like oem going straight and then corners it helped loads.
After that is basic coilovers and some can ride harsh and some not but dont always have the same effect or last as long
Well, my question was intended for any build or brand, but I understand what you mean by too vague
So I guess just general usage or something streetable but also can be used for track or drag.
I posted the question after me and buddy were talking about what would be considered the best suspension brand or setup for these cars, and I couldn't answer him because I don't know nor do I have a preferred brand so I figured I'd post here and see what peoples preferences or opinions on that subject are since it had me curious after our discussion about it.
Been meaning to come back to this to edit it to be more specific tbh, been too busy and keep forgetting LOL
The question re wrote is still vague LOL. You ask for street, race, and drag haha. The best on all of that is not a 1 fits all. So because of this I'm going to base it from a street coilover for you. However if you get coilovers too stiff they are not very streetable and will be rather harsh for even the most normal driving.
So opt for something like flatout, BC's. They have a a good base and if you opt for a soft spring but wont be as great on track even if you up the dampening that's not how you setup stiffness and you need springs to do that properly.
Feals are also decent but cost more when you want custom springs now and you no longer get swift springs so cost more again, so they basically priced themselfs out of a good coilover with options now vs when they first started so that's whey i don't mention them much anymore.
I use BC myself. Semi cost effective but are more aimed at racing. Even on my daily its valving is quite harsh but i accept this as i want a nicer handling road car but put up with the harsh bumps. Spring rates wont work for drag so that's why 3 options are very different and 1 wont really fit for all applications
