Sub setup 1g awd show me what you got.
hey man there are tons of threads on this. Just do a search for "Sub Enclosure" or "Sub Box" and you will get tons of threads with pics and stuff. Good luck :thumb:
Royalty said:
weather is AWD or FWD the trunks are the same.
You might want to look at your trunk and then check out a FWD version. Not the same. Because we have AWD we loose more trunk space. :talon:
hewhoisknot said:
um... we have a hump for the spare tire due to the diff (i believe) for the fwd people... a little trickier to work an enclosure into...
When you take the carpet out of our FWD trunks, there is a dip down which would be just as hard to work with. I just made a new false floor, and attatched some 2-inch PVC pipe caps to the bottom which raised the floor up and made it level. Then it was like starting from a whole new flat trunk minus 2 vertical inches.
i wouldn't say it is jusa as hard to work with. we have a hump that goes up. there for we have less space between the floor and our windows. its very very hard to work around and get a box the size that you want.
i simply fiberglassed into the spare wheel well on my FWD. i'd LOVE the chance to do a custom 'glass enclosure in an AWD. but when i had my AWD, i was more concerned about going fast, that's why i never put in a large system (same with my friends w/ AWDs) my FWD though has traction issues anyways, so i wasn't too concerned. a show car, with a competition system (soon to be 5.1 surround).... my goal is 13's in the Qtr. not too hard to obtain.
but anyways, did you try Sounddomain.com? you might be able to find what your looking for over there. or even Cardomain.com
I had 6 10 inch JL Audio W3's in the trunk of my 1991 AWD Talon. The hump posed a problem, but I put 2 box wedge type boxes in there and didn't have any problems. I took out the part of the back seat that You sit on and mounted my 2 Alpine MRV-1507's there. No room but for one passenger.
