stupid question, the smaller hose off of where the radiator cap is...
ineedagsx
273
Aug 14, 2007
islip, New York
where does that go exactly? basically what im doing in bypassing the coolant hoses to the turbo and i want to do it as easily as possible so i was hoping that goes straight to the turbo... and yes i know that it is a bad idea but i have my reasonings, thanks in advance guy
That should be a radator overflow hose. Also you are gonna fry your turbo.
no not the overflow one, theres another one on the right hand side and yes i know about the turbo i have other plans :) just need to know
Well in that case im not sure. My car doent have one. Is it possible to follow?
not really it goes behind the turbo, i really need someone that has a 4g motor to answer this...
yea i think ## right racer, i was hoping it wasnt, i forgot where it went, i guess thats what happens when you build a motor and put it in drunk LOL
The coolant lines for the turbocharger don't run to the radiator cap/water neck/thermostat housing on a 2G. One line runs to the engine block and the other runs to the water pipe between the thermostat housing and the water pump. I also believe what you have described is the coolant line to the oil filter housing as that is the only line on the water neck other than that for the overflow.
