stuck? cant tell if turbo is blown or what is wrong
zack420aspeeder
61
Sep 29, 2008
brookville, Indiana
ok i was at my friends house and i was leavin and my car started actin ###. it wouldnt rev pas 2k and acted like it wanted to die the boost guage is reading about 3/4 and im not getting any pressure at all and is spitting a lot of black smoke so i think its blown but i dont know can someone please help me
A blown turbo is going to blow blue smoke which is oil getting into the turbine side. Black smoke is from running rich. Take off the intake pipe and wiggle the turbo with your finger to check for excessive shaft play and in/out play. I'd suggest not doing it while the car is hot
Check for boost leaks. Its a very good possibility that is what you might have causing your problem. See if any of the piping is loose.
+1 ^^
if your not getting lot of shaft play then its probably loose inter cooler pipe/ or hose mine did that one day when i was driving scared the hell out of me till i pulled over opened the hood and looked at one of my couplers nearly off the pipe:toobad:
also possible that if he has smoke coming out and turbo is good i hate to say it but posible blown head gasket :( do a block check.
    • george bromwell
    • pma1123
    • Sdcryan1
