stroker build
kendrick
Oct 26, 2014
gainesville, Georgia
alright so i have a 2g gst with a full 6 bolt swap im currently having to get motor rebuilt an want to do a stroker build using my 4g63 6 bolt block an head what all would i need to purchase to have it built my motor is already bore to .20 over head has been rebuilt already with hks 272 cams 3g revised lifters i know i have to get a 2.4 crank but what else would i have to get thanks in advance
More torque is not what you need in a fwd. I would re-evaluate what you want out of the car before dropping thousands into making it a burnout machine.
To answer your question, you need a 100mm stroke crank, and stroker pistons. I would also strongly recommend aftermarket rods.
