Street Tuning Concepts: SAFC Mid Point Correction Factors & Operation
Okay, I understand that not all of us are fortunate enough to own DSM Link or AEM's EMS, so I have put together a basic tuning guide for you guys out there still running the infamous Air Flow Converter.
Before we get started, I would like to thank one of our Wiseman for inspiring this article. kpt4321's articles involving the SAFC have become standard practice for anyone running this device. Heck, it also helped me along the way!
I decided that there were some critical concept factors that needed to be discussed in detail regarding AFC operation, to allow the user to have a better understanding of how it works. I wanted to create a user friendly example forum, that helped the user better understand midpoint averages, and what setting would actually be applied for a given engine load. If you can relate to what the equipment is doing, you can better tune your car. I have included multiple examples to help explain the concept, so I hope you enjoy. :)
Note:
This guide is to help you understand how the Apex SAFC works and is in no way a complete explanation on how to run or tune your car. I am not held responsible for you causing damage to your car. All examples given are just that, examples! Don't assume any setting I have plugged in here will work. Every car is different and every tune requires attention to detail, and concepts of sound tuning knowledge. Also, before we start, I will assume you have read the ENTIRE instruction manual, right? Also, it is wired correctly, you know what all the menus are, and the settings required for your particular vehicle are correct. If you bought your AFC used, Google it, the instruction manual is available online.
Apex SAFC:
Before we get started, we must first understand the concept of the Air Flow Converter.
Basically, (and without getting into complicated detail) the AFC "intercepts" the MAS Airflow Signal coming into the ECU (Hz) and "fools" the computer into thinking less air is entering the engine. Since fuel delivery is primarily based upon Airflow, this will allow you to compensate for larger injectors, by reducing injector pulsewidth.
When you run larger injectors, the ECU doesn't have a "sixth-sense". It doesn't automatically know you have larger injectors, so it won't adjust injector pulsewidth. Basically, this means if your running 550cc injectors, the ECU will spray them as if they were 450's causing you to run rich, (but we'll get to that later). For the most part, when you upgrade fuel injectors, all it means is you have an injector with bigger holes in the end of them that allow more fuel to spray for a given amount of time. (Hint: that's why for the most part injector prices are pretty close regardless of size) And no kiddies, THAT DOESN'T MEAN YOU CAN PORT YOUR INJECTORS!!!
Basic Concept of Operation:
Okay, let's talk about basic AFC operation. As I stated before the SAFC intercepts the frequency signal from the MAS and converts it to a set value based on your settings. How it does this is the AFC has a set of maps based by engine load and rpm. The percentage correction is exactly what it says: it will compensate the percentage you enter at each RPM and Throttle Position, off the actual value measured at the MAS.
For example, if the actual signal coming into the ECU is 500 Hz, and you have a correction factor of (-10%) the new value the ECU will calculate is 450 Hz. Make sense?
So if you have a larger injector, and your car is running rich or sluggish, you must make the correction factor in order to compensate. Ideally, after the correction the injector pulsewidth will be reduced, and the car should operate as though it were stock. Now there is a benefit to this regarding Open Loop Conditions, but we'll get to that a little later on.
The next correction factor you must take into account when tuning with the AFC is Throttle Position Compensation. There are two TP setting included with the AFC, Hi, and Low. Although it seems simple, you need to understand that it's not as straight forward as it looks. Below the low setting, the car will calculate airflow from the tables from your low throttle point settings. Above the high setting, the ECU will calculate airflow based upon the high throttle point settings. Everywhere in between is what confuses people:
Mid Point Settings and Averages: Explained
The important note that needs to be take into consideration when using the Air Flow Converter, is your mid point settings. Most people are misconstrued by this feature, and it tends to complicate some. The AFC operation is not as straight forward as it seems. For example, it's easy to think that if your correction factor for say, 3000rpm is (-10%) then at 3250rpm, (or throughout the 3K rpm range) will be (-10%). Not the case.
As I stated before, AFC corrections are based on indexed tables that will calculate correction factor. At these mid-points it will take the average of the two, just like the graphs you use to do in math class, same thing. The easiest way to figure these values, and allow you to make optimal settings is to determine the average between the to base value settings.
Keep in mind, the AFC is not your airflow table, it's a compensation table applied to the airflow table. Your not making straight adjustments as you would with DSMLink so don't be confused. The ECU will still operate on the same principles, and extrapolate unknown factors in certain modes/ times of operation.
Here is an example kiddies:
If your 4000rpm value is (-10%) and your 5000rpm value is (-20%), then your total correction factor at 4500rpm is (-15%) Get the picture? All you did was take the average of the two values base on the principles of tables and graphs, and found the value at a given midpoint. 4750 would be (-17.5%) and 4240rpm would be (-12.5%), so on and so on. For more info on graph principles, search it or go back to math class.
Mid Point Settings: TPS/ Engine Load
Now to complicate things even further, this principle holds true for your Engine Load Settings as well. (TPS) As I said before, when you're below your low setting, it will compensate airflow flow from your low table, and when above your high table it will use your high settings. Everything in between uses the same average principles as described above. So an example is as follows.
Low throttle point is 30% TPS,
High throttle point is 80% TPS,
Engine load is 40% TPS.
Engine RPM is 3000rpm.
Low Pt Settings: 3000rpm: (-20%)
Low Pt Settings: 4000rpm: (-20%)
Hi Throttle Pt: 3000rpm (-10%)
Hi Throttle Pt: 4000rpm (-10%)
With these settings:
Correction factor with 40% TPS
@ 3000rpm is going to be (-15%)
@ 4000rpm is going to be (-15%)
This is because your taking (-20%) @ 4000rpm and (-10%) @ 3000rpm and finding the mid points in reference to throttle position. The average is used because 40% TPS is between you 80% HI and 30% LO TPS setting. Of course this is only an example to help you understand better, but you need to make your correction based on data logs and Air/Fuel Ratios. Also the AFC has a log feature that allows you to view your total correction factor based upon Airflow frequency signal. Now for all you cavemen out there here is your average equation to find the median. (Mid-point)
X + Y = Z / 2 = midpoint
(-20%) + (-10%) = (-30%) / 2 = (-15%) correction factor
Now for throttle points:
HI TPS (80%) 4000rpm (-20%)
LO TPS (30%) 4000rpm (-10%)
TPS of (31%-79%) @ 4000rpm will be (-15%)
So let's complicate things a little to help you figure this out with mixed values, so you can see how to apply the formula.
Settings:
Hi TPS (80%)
Lo TPS (30%)
3000 Rpm Lo: (-14%)
4000 Rpm Lo: (-17%)
3000 Rpm Hi: (-8%)
4000 Rpm Hi: (-7%)
What is your correction factor @ 3500 rpm at 65% throttle?
Correction Factor @ 3500rpm: (-11.5%)
Correction Factor @ 3400rpm: (-11.4%)
Correction Factor @ 3300rpm: (-11.3%)
Correction Factor @ 3200rpm: (-11.2%)
Get the picture? First find the midpoint between throttle points, and then the midpoint between RPM's given the midpoint calculated values from TPS percentage.
3000 rpm: (-14%) + (-8%) = (-22%) / 2 = (-11%)
4000 rpm: (-17%) + (-7%) = (-24%) / 2 = (-12%)
Midpoint that @ 3500rpm:
3000rpm: (-11%)
4000rpm: (-12%)
(-11%) + (-12%) = (-23%) / 2 = (-11.5%)
Correction Factor @ 3500rpm is (-11.5%) Now it's easy to see where all the points on the table go for RPM by the tenth.
Okay, enough with the corrections, we get it, right?
The SAFC has a neat little feature that will allow to log your airflow correction data, (measured by %) so you can actually see what correction factor you are applying for any given load. Use this tool, it will help you fine tune your RPM points, and dial in those targeted A/F Ratios.
Now, in my personal opinion, the SAFC has one serious limitation: There are no 3-D maps involved with the system. So basically, everything in between is going to be everything in between. No graph scales that allow compensation tables to adjust during your midpoint throttle position. Everything from 31% to 79% (in our example) will be averaged from the Hi/Lo RPM index settings.
Timing Considerations:
Now there is one major change we have to take into account when making Airflow compensations. Ignition Timing!!! Be sure to read the Tech Article titled:
How the SAFC Works by kpt4321
When you enable a correction factor device (such as an AFC) to "trick" the ECU into thinking there is less air, (when there really isn't) your going to get the same advance with a higher airflow, which we all know what that can lead to: Pre- Detonation.
Now that you understand the basic use of the AFC and correction factors, you can read on and best utilize your SAFC. Happy Tuning!
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
