SAFC Tuning / How and Why
The ECU basically has 3 operating modes, closed loop, open loop and limp mode.
Limp mode is reserved for potentially damaging problems the ECU may encounter. The main problem of which, is a nonfunctional MAS. Without feedback from the MAS the ECU has no idea the mass of air passing to the motor. At this point it enters limp mode and runs extremely rich to protect against what could be disaster. This allows you to get your car to the shop or home so it can be repaired immediately.
Closed loop is where you spend most of your time in daily driving. It is a loop that involves the O2 sensor feedback and the ECU. As the ECU receives a voltage from the O2 sensor it determines if the previous combustion cycle was rich or lean. It then uses the Short Term Fuel Trim (STFT) and Long Term Fuel Trim (LTFT) to adjust the fuel delivery for the next combustion cycle. In closed loop mode, the ECU is shooting for an AFR of 14.7:1 which is the stoichometric point where all of the fuel is exhausted during the combustion cycle. This allows for maximum use of the fuel injected and gives you the maximum mpg possible. An AFR of 14.7:1 corresponds to an O2 voltage of 0.50v.
If it determines that the previous combustion cycle was lean, i.e O2 voltage <0.50v and AFR >14.7:1, it increases the STFT which corresponds to an increase in IPW (Injector Pulse Width) in an attempt to bring the O2 voltage back to 0.50v. If the previous combustion cycle was rich, i.e O2 voltage >0.50v and AFR <14.7:1, it decreases the STFT which corresponds to a decrease in the the IPW.
STFT is the ECU's display of what is happening right now, whereas, LTFT is pretty much a running average. If the ECU sees a consistent rich or lean condition, it will average the STFT value into the LTFT and return the STFT to zero. When running a SAFC, you need to adjust the airflow so the STFT and LTFT add up to zero. For example, if the STFT is +5% and the LTFT is -5%, sooner or later they will cancel each other out and both the LTFT & STFT will be 0.
The last mode the ECU operates in is open loop, this is normally considered WOT. In open loop mode the ECU uses things like MAF Airflow, Barometric Pressure, Intake Air Temperature (IAT), Coolant Temperature, etc. to calculate the mass of air entering the combustion chamber. Based on this air mass calculation, the ECU attempts to inject an appropriate amount of fuel to reach the desired AFR from the Fueling Maps.
On a 2g, the highest airflow map is designed to hit an AFR of 9.5:1 when the ECU sees >2.1g/rev airflow. This is rich compared to the closed loop stoichometric value of 14.7:1, but the increase in fuel delivery is used to prevent knock by using the extra fuel to cool the intake charge. When running at WOT, the ECU uses feedback from the knock sensor to monitor engine operation and protect the motor. Keep in mind, that the O2 sensor feedback is completely disregarded during open loop operation.
See, the ECU has what can basically described as 3-dimensional maps for fuel delivery and timing values based on the mass of air being delivered, rpm, etc. For example, at an air mass of 2.1 g/rev the timing is capped by the ECU at 16 degrees of advance. So, if everything is perfect, and within the predefined specs, you will see 16 degrees of timing when running over 2.1g/rev. This isn't always the case. Based on feedback from the other sensors listed above, the ECU will modify the timing value from their preset target. For example, if the IAT is >84F degrees, you will loose 1 degree of timing. So now, at 2.1g/rev, you will only see a maximum advance of 15 degrees.
Timing values are also heavily influenced by feedback from the knock sensor. The ECU uses a linear relationship to pull timing based on the knock count. So the more knock the ECU "hears", the lower your timing value will be. This is how we can use a log to determine knock on a 2g. The 1g guys have it easy, because knock values are output to the OBD port. On a 2g, the ECU does not transmit this value to the OBD-II port. This forces us to "estimate" knock based on the timing curve. For example, you make a WOT pull and you see a steady timing increase from 3k up till you hit 5k. At this point the timing begins to drop, from let's say 15 degrees, down to 13 degrees. Most likely this is caused by knock, but it could also be caused by your coolant temp going over 210 degrees and the IAT going above 84 degrees simultaneously, each of which will cost you 1 degree of advance. What you do in that case, is make another pull and log coolant temp and IAT. If you don't see these values exceeding the limit imposed by the ECU, then you know the problem is caused by knock. At this point, we need to determine what is causing the knock.
Normally with the SAFC, this involves adding fuel in the affected rpm range. But you have to be careful, because there is also rich knock. So, you make the appropriate adjustments on the SAFC and make another pull. If the knock goes away, great! If not, we need to keep making adjustments.
Using the SAFC is like ice skating uphill. As you use the SAFC to molest the mass of air the ECU "sees", the ECU increases timing. Remember, the lower the mass of air seen by the ECU, the higher the ECU will allow the timing to increase. This causes a problem, because we really aren't running a lower value of air, we are just telling the ECU that we are. So as you increase the size of your injectors, you need to remove more and more fuel. When you add larger injectors, the ECU doesn't know, and frankly, doesn't care. It treats them as stock and continues to use the programmed IPW. But since the injectors are larger than stock, the same IPW results in additional fuel that the ECU interprets as a rich condition in closed loop. Seeing a rich condition, it decreases the STFT and LTFT until it runs out of adjustment range. I believe this occurs at -12%. When it hits it's adjustment limit, you get the good old P0170 CEL, Fuel Trim Malfunction (Bank 1).
This is where the SAFC comes in. By lowering the airflow value before it reaches the ECU, we can manipulate the IPW. Now that the ECU sees less air, it drops the IPW and basically compensates for the larger injectors. But this is also what causes problems at WOT. You want larger injectors to support additional flow generated by a turbo upgrade, right? So now we have a turbo that flows significantly more air than stock and larger injectors to support the additional flow. So what do we do? Add a SAFC and manipulate the airflow to the ECU. This works, but causes a big problem. The ECU is now seeing significantly less air than is actually being "ingested" and allows for additional timing over the 2.1g/rev cap of 16 degrees. High timing + high airflow = knock.
This is the problem with running the SAFC, compared to something like DSMLink. It is "doable" but is definitely not the best way to approach the situation. I am running 650cc injectors and a SAFC and have a pretty good tune, so it can be done.
Let's talk a little more about the SAFC's manipulation of airflow since the question of g/rev was brought up.
The Karmen sensor inside the MAS sends a frequency to the ECU based on the air flowing into the system. The sensor contains a vortex generator that creates small swirling in the intake stream within the sensor. When properly detected, the frequency of the vortices are proportional to the volume of air passing through the sensor and knowing the air temp and density the ECU can calculated the mass. As the vortices are created, they are directed to a sensor within the MAS and begin to vibrate a piece of reflective, metallic foil. As the metallic foil vibrates, it causes light to be reflected to, or away from a photoelectric sensor. This creates a square voltage wave within the sensor that is transmitted to the ECU. The faster the airflow through the intake, the faster the foil vibrates, the higher the frequency value passed to the ECU.
Wow, that was fun, wasn't it.This is what I get for paying attention during physics class. Alright, so what do we do with this frequency once it gets to the ECU? Well, why don't we screw around with it and see what happens. Remember that SAFC stands for Super Airflow Convertor and only alters fuel delivery indirectly. So, as you drop the airflow signal with the SAFC, the frequency is manipulated to a percentage lower than what we started with. An opposite effect is produced when you add airflow with the SAFC. This leads to a increase or decrease in the fuel delivered by the ECU. We use this ability to manipulate the airflow signal to compensate for larger injectors or lean out the AFR from the factory 9.5:1.
So now that the SAFC has manipulated the airflow frequency and the ECU has used that information, it gets output to the OBD-II port. One thing everyone forgets, is that the airflow shown on your logger, isn't the actual airflow value. You are getting this airflow value after it has been molested by the SAFC. So, if you want to find the actual airflow, we need to convert using the highest airflow value output to the logger, the rpm at which that airflow value occured, and the corresponding SAFC Hi Throttle correction factor.
Here is the calculation:
Airflow (Value from logger) / ( 1 - SAFC Correction Factor in decimal form corresponding to peak airflow rpm) = Actual airflow
So, for example, let's say your logger shows 26lbs/min of airflow at 6200rpm. You check your Hi Throttle table and see that you have a -21% correction factor at 6200rpm. So, the calculation becomes:
26 lbs/min / (1 - 0.21) = 32.91 lbs/min
What do we do with that number you might ask? I use it whenever I am increasing boost and also to determine what boost I should be running. Why boost more when you aren't getting a higher flow. Higher boost increases the temperature of the intake charge and leads to an increased chance of knock. So why push 20 psi when you can create the same flow at 17psi.
You can also use this to evaluate the effectiveness of an upgrade. Back when I installed my UICP, I made a baseline log after the installation at 17psi and was flowing 30.26 lbs/min. Prior to the upgrade, boosting 17psi I would see a peak airflow of 28.50 lbs/min. I cranked up the boost to 19psi and saw an increase to 32.15 lbs/min. Before installing the UICP, I was seeing a minimal airflow increase when upping the boost, so it would have been self defeating to increase the boost and not get a proportional increase in flow.
So, let's say that we want to determine if we have been placed on the ECU's highest timing map. If so, we can definitively see if we are knocking, which is always a hard thing to determine on a 2g.
We need to convert the airflow value from lbs/min to g/rev, but which airflow value do we use. We need to use the airflow displayed on the logger, not the value after the calculation.
To convert to g/rev you need to use this equation:
(A * 453.59) / R = Airflow in g/rev
Where:
A = maximum airflow displayed on the logger
R = rpm value of A
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Black Ashtray & Cup Holder
    2G Black Ashtray & Cup Holder $35 + shipping and paypal fees* both sides open and shut * all 4...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
