strange ringing near timing side 4g63
Have you check the a/c and power steering, timing belts for proper tension? or that no parts are slightly rubbing the pulleys.
That may be a possibility. This past week I've tore down the engine to change a head gasket. So far most components are good. i'll check if the tension is off.
Just wanted to let you guys know I just finished my first timing and head gasket job. I feel proud of myself.:)
The problem that was causing the ringing is gone and i guess it would be a improper tension belt.
All I have to do now is fix screeching belt. :(
You talking about that power steering belt squeel at start up? Just tighten her all the way up and should go away.
