Straight Answers
NathanCarlK
53
May 17, 2012
Ulysses, Pennsylvania
I'm looking at a few good setup options for a build down the line. What I would like this forum to be is a list of mods that YOU used that WORK good together. No "you could use a 20g turbo" or "I think i'll add 600cc to help" Simply a list of mods that you are using that work well together, and what your HP is aprox at or if you noticed a performance differance.
Ex: Mod Combo
Injen IS Intake, adaptor to spectre air filter, Greedy type s(recerculated). Everything else is stock. Result: Runs good! Sounds Better!
Thanks Guys! :thumb:
There are so many different setups. So many copy cats, and a few unique ones. You will only ever get "you could use this" type of answers because you just have to think about what you are looking to achieve. There are different ways to do many things. For setups that work, you can just view people's mods list, doubt anyone that updates their list will say their car runs like crap.
DSM Forums - View Profile: liquidsilver
BTW gotta get yours updated :thumb:.
Tell us what your goals are. How much HP are you trying to make? How much money are you willing to spend.
This set up works for me and allows for additional growth. Runs on 91 oct, planing to install devils own meth injection to fight off knock. My goal is pretty simple, just trying to run 11s @ 5800ft above sea level on pump/meth.
The go:
Engine
4g64 crank 100mm stroke
Manley Rods rated at 800hp
Wiseco 8.8:1 .pistons
Cometic H/G
Balance shafts eliminated
ARP Main bolts, Rod bolts and head bolts
1G Head
Bronze Valve guides
Ferrea steel valves
Ferrea steel Valve locks
Hi Temp Valve stem seals
SI Dual Valve springs
Manley Titanium Retainers
FP3X cams
HKS timing belt
Kiggly HLA Pressure Regulator
Fluidampr Harmonic Damper
Intake
1G throttle body
1G ITM
Garret GT3582R
Punishment FMIC
Greddy BOV
Exhaust
Punishment Racing T3 Tubular Manifold
Punishment Racing O2 Housing
Tail 44mm waste gate
Punishment Dump Tube.
Punishment 3inch downpipe
Greddy XP 3inch exhaust
Drivetrain
Stock tranny
ACT Streetlite Flywheel
ACT 2900 Plate
South Bend Kevlar/Feramic Disc
Frontline Fabrication Rear Differential Cover
B&M short-shifter and all metal hardware.
Fuel
1050 FIC
Aero motive FPR
ECM LINK
Walbro 255 FP
Lc-1 wideband o2
Misc
Stock MAF
BOV Recirculated
The show:
6000K HID Projector combo
Enkei Rims
FMIC
Exhaust
Other than that, all stock exterior, I keep the stickers under the hood.
How many threads do you plan on creating so people can perform searches for you? Curious...
So basically you want people to reply saying "check my profile" if they like their mods and how they work together? You might want to check the Dyno List and Timeslips List and check profiles for those cars that have the number goals you're shooting for. Probably be faster. And if you need to confirm if that's their current setup, just PM them. Doubt you're going to get many replies with the info you're looking for here in the Newbie forum.
On a side note, I would ask that you use a better thread title that is more descriptive. We're starting to move threads with non-descriptive titles to the Graveyard since people are continuing to disregard our pleas on this.
