ECMlink Stock tune help
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
I bought dsmlink used and i have a stock car. Im
New to dsmlink and the guy i bought it from said it has his stock tune. Im wondering how can i set up ecmlink to run 100% stock like factory?. I have ecmlink v3 on my laptop just not hooked up to the car. Is there a way to set it up stock i know that when u buy new you can choose to have it stock or whatever size injectors u want but i got it used so it has some othere bigger injector settings thanks its going on a 95 talon awd
Also couldent get my wideband hooke up
That last link you sent me. I loaded it on my computer so all i have to do is copy to ecu and the car should run like stock?
Nope, as it says that just set the config part back you still have to reset the direct access data.
This all assumes that your ECU also has a current version of DSMLink 3.X installed. What you can do is dictated by the ECU software not so much the client on your computer.
I hooked ecmlink on and pulled up the current tune and pulled up the stock tune tabs and i copy them on to the ecu but some tabs read cannot copy becouse it dosent match the ecu
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
