ECMlink Stock GSX Base Tune
Adrian216
3
Feb 24, 2020
Cleveland, Ohio
Hey guys I just picked up dsmlink v3 from a local doing a part out.
I was hoping y’all could help me out with getting a base tune for my 2g gsx. I’m completely new to ECMLink so please bear with me.
The car is completely stock aside from a down pipe and 3” apexi exhaust.
Stock 450 injectors
Stock intake
Stock manifold
Stock t25
Let me know if you guys need anymore info.
Thanks in advance.
Here are factory fuel and timing tables you can download. You’ll see an arrow that points in both directions on top in direct access (DA). Those are to reset setting back to stock. Any changes in DA, the engine has to be off, then hit save when you’re done.
http://www.ecmtuning.com/wiki/v3configs
Cool, thank you. Very much appreciated.
Stock with ECMLink - this is a rare opportunity.
Install a MAP sensor so you can play with the ECU based boost controls.
Also, once you get a Widband O2 up and running, you can start to play with tuning.
