2G Stock GSX missfire
605jdm
169
15
Feb 7, 2016
siouxfalls, South Dakota
I just bought my gsx and drove it home for about 5 hours then a few days later the check engine light came on and came up as a missfire on cylinder one and I could hear it too. I got new heat 7 spark plugs and ngk wires and checked the spark that was all good but it's still miss firing. Please help I can't figure it out. Also my mpg dropped to 17mpg.
LOL This guy is cluttering the forums with his problems.
btw everything has already been asked before. If these cars dont make you a mechanic then there is no faith in keeping it, if you want the honest truth.
Unplug one injector at a time to see how that affects it at idle(sometimes you can tell which injectors are working by touching/listening to them). That will tell you what cylinder it is. Could be a bad ECU driver or bad injector.
I pulled out all the injector clips one at a time and it didn't stay the same for the first one. The engine just shook and ran really bad.
Possible bad Coil Pack, Bad Power Transistor, Bad Cam Position Sensor, plugs, plug wires, clogged injector, dying injector
if you have spark and you already tried plugs then you should swap # 1 injector with # 4 to see if the misfire changes . also did you check compression cause maybe it could be a mechanical problem .
I already tried swapping them I will get a compresion check I guess. It that comes up good what else could it be?
Just a side not, my buddy picked up those same plugs for his car. Drove it for about an hour and misfire. We swaped the plug to a different cylinder and that cinder then miss fired. Turns out one plug was bad from the factory. Replaced bad plug and no more misfire. Just a though guy at napa said it is fairly common to receive a bad plug.
As what others are mentioning, swap the injector/plug/plugwire with another cylinder's and in different intervals and see if it jumps to a different cylinder. That will rule out bad injector, bad plug, bad plug wire. Test your coil pack and CAS with a ohmometer. then check your fuel pressure.
These are your only options.
Does your problem come and go, or is it always misfiring? I had an intermittent misfire issue once... it would run fine when the engine was cold, and start misfiring after fully warmed up. Bad power transistor - I could put it in the freezer and then the car would run a little longer since the transistor took longer to heat soak. Whenever it got hot enough, it stopped energizing one of the coils and caused the misfire.
its always going and started getting really bad because my alternator is going out. I ordered a new one and will see what that does to fix it. After that im getting 850cc injectors.
