Stock cams?
i got a set of 1g cams at home. not sure if you need them or 2g. theyre off of a 92 talon tsi awd i believe (was my buddys then i bought the 6bolt motor off him) PM me if your interested. def not asking $300 for them. im sure we can work something more in your benefit and for me too. thanks!
as far as i know, you can use the stock cams from a 1g. whether or not they are 264/264 im not sure. you will probably have to use your cam gears on your cams now but i do have the cam gears with the cams from my 1g 6bolt.
i would ask others or wait to see if any1 posts anything else to this thread. be sure to let me know if you want the 1g cams i have. ill include the gears too for free. i dont care.
I sent you a pm about 2g cams I have for you. All cams for a 4g63 from 1990-1999 are interchangeable. I have BC 272's and they are a direct bolt in as would the 264s youre asking about as long as they are for a 4g63 dsm. You can use the stock cam gears and everything else. If you want to rev them out past 7500rpms, you should probably upgrade your valve springs and retainers.
I was also wondering about just dropping in a set of kelford 272's as I dont have adjustible cam gears and was wondering if I could just drop them in and not have any problems with it. I ran out of money after all the money i spent on other upgrades.
you can use the stock cam caps and with a non agressive cam you can use the stock valve train and not rev past the stock limiter.
I have some hks 264's.. im only tryin to get rid of the exhaust cam for 100 shipped cause i want a 272 but pm if interested. i might be interested in getting rid of both for 320 tyd also.. but would rather just sell the one. lmk
