Stock/Aftermarket Alarm Disable
PhatEclipseGST
44
Mar 15, 2005
ADAMS, Massachusetts
How can I disable my stock and aftermarket alarm. Pulling the fuse does not work. My alarm is acting up and keeps my lights on and kills my battery. Where can I disconnect its power source? or whatever is making it act up.
If it is an aftermarket alarm unplug the brain it will be located on the underside of the dash on the driver side. As for a factory alarm, that i am unsure of. However most places that but an aftermarket alarm on will disable the factory one when they install theres on.
There is a peice of the aftermarket alarm mounted to my steering column.. Has afew lights and wires coming from it. 2 of 3 wires are unhooked cause I was messing with it. Not sure if they will do anything
