2G eclipse spyder 2g agency alarm disable
Dsm2g15
45
Oct 28, 2021
México, Texas
QI want to completely remove the spyder gst alarm, it activates alone with the other alarm that I have installed and it is living me crazy I heard something about a Green wire to ground really cancels it
you can't just remove it like an aftermarket alarm system.
try this to disable it
I had the same problem on mine. I ended up removing the trunk lock and replacing it with a rear camera. In doing so the alarm system thinks there is still a door open and never fully arms. There is a way to disable the system by cutting a wire... I'll have to look it up though. I have the info, just need to find it.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
