TheYoungDSMer
- 0
- Apr 25, 2012
Columbia,
Missouri
I recently bought an Eagle Talon Tsi (M/T), Test drove it, Then Got it home, The car set 4 days after arriving at my home. The car came with both a fair share of issues and aftermarket parts, It has an SAFC II, AEM wideband, EVO III Big 16G, 550cc Injectors, along with some other less important parts. The car used to be a stock 7 bolt, but then was swapped to a 6 bolt, with the 7 bolt head. The car ran the day of the purchase, but we had been told it had a bent intake valve on the 4th cylinder. The car made it home fine, no issues at all. A work week passed and I went to go work with the car, then it just cranks and cranks. So then came the test for fuel, spark, and compression. The car has spark, 12.34V on the injectors, havent checked resistance, There is fuel on the fuel rail, and is fuel making it to the engine, because there was fuel on the spark plugs when I checked for spark. I think that the problem may be ECU, but I was reading and people said the 2g ECUs don't usually fail, so as of now I'm at a stand still and can't drive my new vehicle, If anyone has any ideas, how to help or what I can do, Please Help
Thanks in Advanced!
Thanks in Advanced!
I'm thinking the issue may be either a flooded engine (A long shot in my mind), or I may have bent more valves driving it home, It was a 3 hour drive.....any opinions? I'm pretty sure the issue is compression, and I think the car tries to start the first go round when I start it, but just makes a loud sound then cranks over and over again
