Starts but dies, then starts again.
whitesmoke
58
Jun 22, 2009
Duluth, Minnesota
i have a 95 talon tsi with a 6 bolt swap. When it sits over night and i try starting it in the morning it turns over and starts but then dies. I turn the key off then start it again and do it probably 3 more times and then it starts and idles fine. Any clue what would cause this?
it also sounds like its camd when its just sitting there.. could that have to do with the starting issue to?
No prob, But do make sure you put a voltmeter on your battery as well, You should be reading close to 14 volts while running. If not then you have either a bad alternator or battery.
These can cause problems like this too.
Ok I checked the battery it's fine, the alternator is fine. I had it
Scanned and came up as P0300 random misfire.
Fix the random misfire, I'd suggest doing a full tune up- plugs, wires etc, if that doesn't fix it then start looking into testing the coil pack
you can test the coil packs before it all just get the car running and start pulling wires if you pull one and the engine doesn't change in sound thats a bad coil pack, switch out the plugs and wires this other eclipse I was working on had the same problems and the fact I didn't have the plugs set up right could have been an issue =p.
  • Wanted 6 bolt NT water pipe
    • chrisman287
