1G Starting problem.
mitsuowner1991
303
7
Sep 29, 2009
West Keansburg, New Jersey
So SOMETIMES when I go to start my car and turn the key the starter dosnt turn. So I have to turn the key on and off and bunch of times then the starter will turn. I've replaced the starter and it still does the same things. I've also checked all my grounded points. There good. Could it be something is the KEY ASSEMBLY?
Ok. I'm so happy I got my car going. There was something wrong with the fiav. It kept leaking coolant into the throttle body. So I got a block off plate. And made sure I have no boost leaks. And it's all good. The one question I have is what does it do if you move your TPS sensor. Mine is at .535 at idle. But I've hear of people having them at .610 and lower.
No I don't have ecmlink. Here's one more question I have. I had the engine rebuilt and the head rebuilt. I should probly check the head bolts and make sure they are still fully torqued.. sooo all I have to do it take the valve cover off correct? And start at the center and work my way out.
It would smell sweet so I don’t think it’s getting in your combustion chamber. Heater core is to the left of the glove box but if it’s small leak you might not see it. Maybe you’d smell it when you turn the heat on when car is hot
How low is it when you open the cap?
Only a little bit. I'm just getting the car back on the road. I got insurance but now I have to wait till may 6th to get registration and plates because of the DMV is appointment only now cause of the virus. I do wanna say the heat dos smell sweet tho
As I remember tho it starts to over heat because the coolant gets low. But I think that was because my fiav was leaking into the throttle body. I fixed that problem by puting a block off plate and looping the coolant lines.
