Starting issues - No / Doesn't / Won't Start - MERGED
prodsm
258
Nov 12, 2002
canada,
All "my car won't start" discussion threads are merged HERE. We've basically made it easier for those who insist upon not searching by grouping together all threads from those with similar issues so you can just scroll through and see some possible solutions. To search for info within this thread, use the "Search This Thread" feature in the black bar about 3" above what you're reading right now.
Could be anything from a loose battery terminal to internal engine damage, and literally everything in between which may involve the electrical, fuel, and ignition system...possibly even something that you screwed up while working on the car yourself. While it's unlikely we're going to diagnose and solve your problem over the internet, feel free to discuss any possible solutions.
I live in Canada and right now its not very warm out, about -30c
my car does not have a block heater too keep it warm.
I tryed to start my car this morning and it wouldent start, ive had this problem before but this time, the car doesnt crank at all it just makes a sound that sounds like an electric drill.
Whats wrong.
Thanks
The ECU won't do a damn thing without a signal from the CAS. The cold start sequence is by default to spray all four injectors. They should still pulse. Warm start pulses all 4 once, then all 4 again for a shorter duration, then starts to sequentially fire them. They don't batch fire. The engine either uses the cold start mode, or the warm start mode. A bad coolant temp sensor will not cause a car to not start. There is no crank sensor. The cam angle sensor controls everything.
I guarantee you this is incorrect.
^ For what's it's worth I agree with Mr. Colt. I've seen plenty of cases where the only thing wrong was a broken connection to the ECT sensor that kept the car from starting because the ECU proceeds to flood the engine thinking it's something like -39F outside and it needs to dump tons of fuel so some will atomize and ignite.
Well it was the CAS. Swapped it out and the car started. But for some reason link is reading 80% throttle without my foot on the gas. I checked the wiring for the q45 and it's correct. On this note I can't get the car to idle,
Anybody have a stab?
What you guys think about this setup (prices from extremepsi.com):
) ACT Xtreme Street Clutch Kit $569.95
2) ACT Streetlite Flywheel $239.95
3) Competition Clutch Release fork / Pivot Ball forged steel $89.99
4) ARP Pro-Series Flywheel bolts kit $46.95
5) OEM MItsubishi TOB U$32.31 (I won't use the ACT one)
Car runs Evo III 16G at 23 psi, 750cc FIC, Apexi AFC Neo, Walbro 255, 2.5" exhaust, K&N Fipk...
Got a new ECU and test it out, car started up and drives fine. seems like even tho i repaired the caps on my ecu, the board was still bad.
make sure to check if your getting spark, and fuel as long as the damage is toward the rear of the car there shouldn't be any damage done to the engine
Ok i have a 90 gsx bought it with no motor bought a motor off my buddy came outa a good running car the car cranks but no start...
checked spark had no spark
checked fuel had no fuel and no injector pulse... replaced the fuel pump and fuel lines filter and mpi... i have fuel pressure but injectors are still not pulsing... tested injector resistor pack thats good... tested cas tdc worked the other wire didnt so bought a known good cas went over fuel and spark test i have fuel pressure i have spark now!!!! but no injector pulse still i have voltage at my injectors but no ground... forgot to mention i also had sent my ecu into ecmlink and they tested it both tested good on there bench and in a car so i am STUMPED! i am an auto tech ive owned many many dsms that ive bought non running and running but have never had so many issues ###zzzzz someone enlighten me btw the car sat for a year before i purchased it kid ripped it apart after he bought it from someone who blew it up... harness doesnt look hacked at all HELP!
try disconnecting th battery and then reconnecting it.. ive done the same thing in my gmc jimmy but it was a hard drop off a rock wall.. all the shock sensors took it as a collision so it shut the fuel pump off to prevent a fire.
I am having the same problem and i have read and keep reading with no luck so far. Im curious as to what has fixed others that has had the same problem.
i did all of that and i found a vac leak. i repaired it and now it doesnt immediatley shut off but it still runs like crap. at idle it seems like it has a misfire and the throttle response sucks i also feel some sort of vibration after 2000 rpms what can i check ### i dont really have the money to replace ramdom stuff so i just need to know how to check stuff.
Hello guys I am back I have currently purchased another dsm it is a 91 Plymouth laser fwd turbo that has 34k original miles that I just dropped a fully built motor into an now it will not start I have checked everything I can possibly think of I have spark I have compression and I have timing the only thing I can't figure out is fuel related I have replaced the fuel pump and I have even replaced the harness to the fuel pump and I have checked every fuse and relay I could possibly think of and I still can't get it to get fuel any helpful advice would be awesome I am also running dsmlink v3 please help me I have considered hard wiring the fuel pump to a toggle switch but would this be bad to do please give me some helpful advice I have been messing with this for about a month also the fuel filter is brand new
I'm getting spark across all cylinders and I have plenty of fuel....cranks but doesn't start....car ran then I pressure washed the engine 2 weeks ago and ever since doesn't start...95 tsi....it's a 7 bolt all stock except hks bov full exhaust and greddy smic....any ideas????
  • Wanted 1g WTB 1g eagle talon A-pillar trim.
    Looking to buy driver side A-pillar trim, with pods preferred.
    • Walnuts
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
