Stalling out during idle.
joeym4130
296
Dec 8, 2003
philly, Pennsylvania
I need some ideas on what to check here. The problem is that the car will idle around 650-900 for a bit and randomly stall after a few seconds up to a minute of sitting idle. I cannot bring the idle up higer even with the BISS all the way out it still idles at that 650-900 and then will stall. Exhaust smells a bit on the rich side, but not major. The car starts right back up after stalling with no problems. I thought maybe the ISC, but the coils read good. ECU?? O2? I don't really know what else to check here...car drives beautifully otherwise....thanks guys.
Have you messed with the battery? One time I had messed with my battery to clean off all of the corrosion and when I started it back up my car did the same thing. So I unhooked it and hooked it back up again and it worked fine:confused:. So I think I didn't hook it back up right the first time so maybe thats what happened to you. Did my post make any sence? :laugh:
