rpg_dog
- 44
- 0
- Sep 20, 2008
Colorado Spring,
Colorado
So last week on my way to school I was pulling off of the freeway and started hearing a loud clunk from my motor so I pulled right over. I had been battling some pesky oil leaks from my dipstick and oil supply line to the turbo for a bit now so assumed one of the leaks had grown and I lost enough oil to spin a bearing. I added some oil, started the car, noise was still there even at idle. I had the car towed home, turbo had lots of free shaft play and I chipped a fin on the compressor wheel. The car wasn't even low on oil, the oil supply banjo bolt was clogged, it ended up having a piece of rubber from a rubber coated washer I had tried to use to stop the leak on the supply line.. Dumb move.
So I ordered a 20g compressor wheel and a rebuild kit for the turbo, but decided to go ahead and drop the oil pan since my car is out of commision for the moment.. ILooked like a bunch of glitter in there
the number three cyinder rod had a good amount of play to it, the bearing was almost non existant.. None of the other bearings looked too bad, but had metal shavings starting to clog the oil passages. I cleaned all that i could with brake cleaner and qtips and replaced all the rod bearings.
I realize that this deserves a full out rebuild, but I have neither the time or the money right now to do that, so I need to get this car running as best as possible without pulling the motor. I have plans to get a 2.4L block when it gets warmer, but I need this car running at least til spring when I can ride my motorcycle everyday.
Tomorrow I plan to take some clean oil and run it through the motor in hopes of flushing out and remaining metal shavings. Is there anything else I can do in order to make sure I dont just blow this motor and turbo as soon as I am done putting it back together?? I'll also poke around the head tomorrow and see if I can find any shavings that made their way up, I guess I should go ahead and pull off the oil pump and filter housing too huh?
And also, when moving up and down the number 4 piston, it makes an almost hissing sound, as if air was rushing out a small hole. I had some oil above the spark plug, looks like a bad valve cover gasket.. Even after I cleaned the oit out and removed the plug, the noise remains whenever that cylinder moves. Is this normal? I never noticed it before.
Ryan
the number three cyinder rod had a good amount of play to it, the bearing was almost non existant.. None of the other bearings looked too bad, but had metal shavings starting to clog the oil passages. I cleaned all that i could with brake cleaner and qtips and replaced all the rod bearings.I realize that this deserves a full out rebuild, but I have neither the time or the money right now to do that, so I need to get this car running as best as possible without pulling the motor. I have plans to get a 2.4L block when it gets warmer, but I need this car running at least til spring when I can ride my motorcycle everyday.
Ryan
