Spun Balance Shaft bearing Block fix method
mechanix565
165
Apr 19, 2009
Pawtucket, Rhode Island
so my talon spun a balance shaft bearing (rear bearing on the exhaust side of the block) and the balance shaft banging around in there wiped out the hole (couldnt even fit in an oversize bearing.( i knew it had spun out but didnt think to check if a new bearing would go back) so i had the block hot tanked, resurfaced and bored. when i got it back and realized my BSE kit didnt fit i had to come up with something and here it is... forgive me if someone already realized this but i didnt see it on here anywhere so i just wanted to make it known
on the balance shaft "hump" on the front of the engine below the exhaust manifold you will see two philips head pipe plugs. one in the front one in the rear if you remove a plug it gives you a direct shot at the oil galley hole. the oil hole is an identicle size as the threaded pipe plug hole in the block. so all you need to do is go to your local Fastenall or bolt store and get a LONG metric bolt the same thread as the plug (i forget what the thread is) and screw it all the way in until it bottoms out and it will block off the oil hole so you can reuse your block. i did it and have over 1000 miles on the motor 85-90 psi cold 30 hot idling have no issues.
edit: this is on a 6 bolt block i dont know about 7 bolts if they are the same or not.
Also you can drill and tap that inner oil passage and install a small bolt or allen head cap screw, then re-install the outer plug.
