- Thread starter
- #101
greengoblin
Supporting Vendor
- 1,571
- 398
- Mar 10, 2006
McKinney,
Texas
7075 t6 for the center pin and sleeve.
Nice Kevin!
Now i need to make the polyurethane version for all of us regular DSMers
This joint needs to move freely in multiple dimensions. Poly bushings won't let it move the way it needs to. It has to be either the stock rubber or a spherical bearing like greengoblin used.
Nice work on the bearing. I was picturing something very similar for my own setup before I realized it isn't a track car and rubber bushings keep the family happier
I think you could make this out of poly. It would however have to be the right hardness for sure.
I was under the impression that the compression arm would swing down in the middle if a spherical bearing were put on the inboard end.
- Jtoby
I was wondering about this as well.
Also, wouldn't having spherical bearings on both the inside mounting points of both the lateral and compression arm allow the knuckle to swing around "too freely"? Which would change caster and toe under braking or acceleration.
I might be completely wrong as well.
My model doesn't show any free movement of the spindle from spherical bearings. It's a messed up lower "A-arm" (in that it involves two separate arms and two ball joints, etc), but it still acts like an A-arm that merely deforms at the vertex in a predictable way as the wheels are steered. But the compression arms flops downward in the model, stopped only by the limit in the rotation of the ball-joint on the outer end or by hitting the ground. But, as DG will soon tell us, I'll wager, my model stinks.
- Jtoby
I was under the impression that the compression arm would swing down in the middle if a spherical bearing were put on the inboard end. Was I wrong? It wouldn't be a first time.
- Jtoby
Two words: bungee cord.
I think the small bushing insert to restrict roll in that direction sounds like a good idea if it is indeed a problem. I guess we'll all wait and see.
Laugh all you wish at the bungee-cord solution, but something like that - a door-spring - was what occurred to me first.
They are still on my sketch pad I will have to make a presentable drawing and then scan it. Should get it done today or tomorrow.
Today or tomorrow has passed...by a while
+1
My family just got another new pet: a rabbit with floppy ears. This reminded me of the compression-arm issue. Update?
In your SPC sleeve drawing, is the material 1 3/8 x .120 DOM tube? I can't tell what the second dimension reads.
What material were the crossmember bushings and washers made from?
These are the drawings I'm missing Kevin, if you happen to have them lying around or could possibly make new ones.
-rear knuckle spacers
-rear UCA cones
-compression arm sleeve
-compression arm dog bone
I think that's it, unless you know of some drawings you haven't posted in here.
