speed sensor bolt stripped
Beanokid69
355
Oct 7, 2003
San Jose, California
So I was changing my speed sensor when I accident dropped the bolt inside the transmission (had to drop the tranny to get it out :ohdamn:). I got it out and attempted to put the speed sensor on and it seems that the hole (tranny side) was stripped by the previous owner. :rolleyes:
Should I re-thread it and get a larger bolt or try and find a longer bolt that dips into the "good" threads?
ya im gonna try and find one...if not ill go ahead and try using a standard size bolt before busting out the taps.
thanks though:thumb:
I wouldn't recommend to use bigger bolt which you have to drill the speed sensor to be able to bolt it on, the speed sensor hole is for a 10mm bolt, so if you go 12mm, then you will have to drill the sensor.
If I were you, I would helicoil it and you will still reuse your bolt.
no your right 12 would be way to big i was thinking of trying a 7/16 or 3/8...heli is also a good idea but i dont want it coming out if the sensor doesnt work...the sensor i have is from a 95 and the gear is slightly bigger...being as the car is new to me im not sure if the tranny is a 2ga so im trying this gear as per the original gear (97-99) is all tore up.
could be that i have to pull the sensor again shortly and dont want to deal with a heli coil coming out with the bolt when the tranny is back in the car...
typical dsm owners day :rolleyes:
plan b...ziptie it LOL ;)
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
