2G SPEED DENSITY ON ECMLINK LITE?
cezargto10
Feb 14, 2015
San Antonio, Texas
Can you run speed density on ECMlink V3 lite? If yes, what do I need to run speed density?
Can I install the plug and play harness? With The iat with the map?
Yes you can use the plug and play harness but you'll save yourself some time if you don't and wire it into something like egr or another component you can delete. This is to run the maf in conjunction with SD for the initial dial in using the automated feature of link.
Is there a wire diagram how to wire it to the egr or something else? Is the ecmlink lite has the automated feature of link?
where is the best place to install/place the OmniPower GM-style 4-bar MAP sensor and get the vacuum/boost ?
